Sep 28th, 2024, 8:17am
A question about delta sigma modulators stability (Read 2370 times)
aidnaal
Jan 03rd, 2008, 3:17am
In delta sigma modulators the maximum SNDR is given by the famous equation of Shreier book;
But in most cases this is not valid and the measured or simulated SNDR is below this value. In Shreier book it's said that in an unstable DS modulator the SNDR is below this value, and the unstability causes the degradation in SNDR. Could you please explain that what is the criteria for stability and how we can recognize if a modulator is stable or unstable?
Thanks a lot.
Berti
Re: A question about delta sigma modulators stabil
Reply #1 - Jan 6th, 2008, 10:16pm
It is not possible to give an accurate analytical expression for the overload level (stability) of a DS modulator.
However, check CLANS (NTF optimization tool), which is part of R. Schreiers DS-toolbox for matlab.
There it is described how stability is determined without simulation.
HdrChopper
Reply #2 - Jan 20th, 2008, 5:05pm
Another extra piece of info.
In that book youŽll find that stability can be predicted based on the value of the NTF as frequency approaches infinite. The criteria change depending on the modulator being single or multi bit.
Tosei
Keep it simple
