Sep 18th, 2024, 11:20am
question about switches (Read 2151 times)
James Bond
Jan 06th, 2008, 2:26am
Hi, all,
I designed a switch to switch off the capacitor, during the simulation when switch is off,  I found that the AC signal is almost blocked, with 0.9Vpp input to the switch, only 0.5mVpp passed, but the input signal has a dc level about 0.9V, and after the switch, it has a dc level about 0.4V, Can I consider the switch is off ? Since after swith is the capacitor, so I think the dc will not affect my ac operation , right ? Please give me some suggestions.Thank you very much.
james
Re: question about switches
Reply #1 - Jan 6th, 2008, 9:57pm
Hi James,
Would you please post the schematic and the waveform? I think that the switch is switched off.
Yawei
Berti
Reply #2 - Jan 6th, 2008, 10:13pm
Since the switch is off, you basically have a capacitive voltage divider. Therefore you can easily calculate whether the 0.4V is reasonable or not.
