fedora
Shanghai
I attempt to simulate phase modulation with the PSS and PAC analysis. The circuit is shown in the attachment. Since the amplitude of the inverter output is limited by the supply voltage, I think the PAC result contains only PM contents at the vout node.
When the inverter in the fig is a transistor level module, the simulation is sucessful. While I replace it with a verilogA module, the PAC magnitude is 0 at the vout node. How can I write a verilogA invertor which can reponse the PAC correctly. The netlist is as following:
simulator lang=spectre global 0 include "/tools/ic5141/tools/dfII/samples/artist/ahdlLib/quantity.spectre" parameters fref=100M INV (vin vout) not_gate vlogic_high=0.6 vlogic_low=-0.6 vtrans=0 tdel=0 \ trise=100p tfall=100p V1 (vin 0) vsource dc=0 type=pulse delay=0 val0=-600.0m val1=600.0m \ period=1/fref rise=100p fall=100p width=0.5/fref-200p pacmag=1 \ fundname="VPULSE" pss pss fund=100M harms=100 errpreset=moderate tstab=12n pac pac sweeptype=relative relharmnum=1 start=100 stop=20M + dec=10 maxsideband=5 annotate=status freqaxis=absout ahdl_include "inv.va"
The file inv.va is as following: `include "discipline.h" `include "constants.h" module not_gate(vin, vout); input vin; output vout; electrical vin, vout; parameter real vlogic_high = 5; parameter real vlogic_low = 0; parameter real vtrans = 1.4; parameter real tdel = 2u from [0:inf); parameter real trise = 1u from (0:inf); parameter real tfall = 1u from (0:inf);
real vout_val; integer logic_in; analog begin logic_in = V(vin) > vtrans; @ (cross(V(vin) - vtrans, 1)) logic_in = 1; @ (cross(V(vin) - vtrans, -1)) logic_in = 0; vout_val = !(logic_in) ? vlogic_high : vlogic_low; V(vout) <+ transition( vout_val, tdel, trise, tfall); end endmodule
