Aug 15th, 2024, 10:41am
simulating phase modulation with PAC (Read 4474 times)
fedora
Shanghai
Jan 09th, 2008, 6:56am
I attempt to simulate phase modulation with the PSS and PAC analysis.
The circuit is shown in the attachment. Since the amplitude of the inverter
output is limited by the supply voltage, I think the PAC result contains only
PM contents at the vout node.
When the inverter in the fig is a transistor level module, the simulation is
sucessful. While I replace it with a verilogA module, the PAC magnitude
is 0 at the vout node.  How can I write a verilogA invertor which
can reponse the PAC correctly.
The netlist is as following:
simulator lang=spectre
global 0
include "/tools/ic5141/tools/dfII/samples/artist/ahdlLib/quantity.spectre"
parameters fref=100M
INV (vin vout) not_gate vlogic_high=0.6 vlogic_low=-0.6 vtrans=0 tdel=0 \
       trise=100p tfall=100p
V1 (vin 0) vsource dc=0 type=pulse delay=0 val0=-600.0m val1=600.0m \
       period=1/fref rise=100p fall=100p width=0.5/fref-200p pacmag=1 \
       fundname="VPULSE"
pss  pss  fund=100M  harms=100  errpreset=moderate  tstab=12n
pac  pac  sweeptype=relative  relharmnum=1  start=100  stop=20M
+    dec=10  maxsideband=5  annotate=status  freqaxis=absout
ahdl_include "inv.va"
The file inv.va is as following:
`include "discipline.h"
`include "constants.h"
module not_gate(vin, vout);
input vin;
output vout;
electrical vin, vout;
parameter real vlogic_high = 5;
parameter real vlogic_low = 0;
parameter real vtrans = 1.4;
parameter real tdel = 2u from [0:inf);
parameter real trise = 1u from (0:inf);
parameter real tfall = 1u from (0:inf);
   real vout_val;
   integer logic_in;
   analog begin
       logic_in = V(vin) > vtrans;
       @ (cross(V(vin) - vtrans, 1))  logic_in = 1;
       @ (cross(V(vin) - vtrans, -1)) logic_in = 0;
       vout_val = !(logic_in) ? vlogic_high : vlogic_low;
       V(vout) <+ transition( vout_val, tdel, trise, tfall);
Frank Wiedmann
Munich, Germany
Re: simulating phase modulation with PAC
Reply #1 - Jan 9th, 2008, 7:55am
Reply #2 - Jan 9th, 2008, 11:36am
Frank's post suggests that the problem you are having is that the limiter you are using abruptly switches, and so cannot pass the small signal. You would be better served using a limiter that has finite gain in the transition region. That is relatively easy to do with a limiter, but then you will see some small amount of AM at the output of the limiter. Alternatively, you can use the PM modulator given at www.verilog-ams.com.
fedora
Shanghai
Reply #3 - Jan 9th, 2008, 10:08pm
Frank Wiedmann wrote on Jan 9th, 2008, 7:55am:
Thank you and Ken. I am in fact simulating a PLL and the link is what I want.
