vivkr
A few more points in addition to the excellent ones from Tosei:
1/f noise may also be easily modulated out of band with chopping or correlated double sampling (CDS) at the cost of additional complexity and in case of CDS, extra noise and power consumption.
An important point which is often overlooked is the possibility of actually improving the noise performance of your amplifier itself. The (4/3)kT/Co limit is the limit on the total noise power in the entire relevant bandwidth of the opamp. However, this assumes
(a) that the noise comes only from the input pair. An assumption which is unfortunately not true. The other transistors will also add noise, and depending on the necessary swing and the quality of design, the additional noise from these devices might become significant. In a folded cascode amp, there are noise contributions from the P and N current mirrors in addition to the input pair, if we ignore the cascode noise contribution. The gm of these mirror devices must be significantly smaller than the gm of the input pair to suppress their noise. In a poorly optimized design, this is not the case. You should try to quantify the total noise power in band vs. the noise power due to the input pair as a quality factor. A good value to aim for is to get the total noise power of the amp to be between 20% - 30% greater than the contribution of the input pair. If you can achieve this goal, then you can be happy.
(b) Remember that although the total noise contribution is limited by C0, the noise floor will be reduced with higher gm. This helps if you are aiming for a continuous-time application where the noise is of interest in a small bandwidth only, or where you have some stages later on which limit the bandwidth.
(c) Finally, you should seriously consider using another opamp topology. Folded cascode opamps are the noisiest from a simple analysis perspective because you have 4 additional transistors (apart from the input pair) adding their noise.
Regards Vivek
