Sep 18th, 2024, 9:22am
question about tuning range algorithm (Read 1703 times)
James Bond
Jan 10th, 2008, 1:12pm
Hi, all,
Can anybody recommend some materials about tuning range algorithm in crystal oscillator or programming crystal oscillator? Thank you very much.
james
Visjnoe
Re: question about tuning range algorithm
Reply #1 - Jan 17th, 2008, 5:38am
Dear James,
I have never implemented a tuning range algorithm for a crystal oscillator, but I would just like to mention that this might not be feasible
if phase noise is of importance. Typically, you will use a bank of binary scaled capacitors with MOS switches in series. The Q factor of these elements can never match the intrinsic Q of your crystal.
If phase noise is of no importance, I would use a binary scaled capacitor bank in combination with a binary search algorithm. The crystal oscillator clock drives a counter which counts for a fixed amount of time T. Every time T, you compare the count value with a wanted value.
Kind Regards
Peter
« Last Edit: Jan 17th, 2008, 8:35am by Visjnoe »
