Aug 17th, 2024, 1:18pm
ESD protection for Power Amplifiers (Read 276 times)
Faisal
Jan 11th, 2008, 7:02am
I am looking for ESD protection structures for Power Amplifier. Any references (books, papers) would be helpful.
Faisal
Faisal
Re: ESD protection for Power Amplifiers
Reply #1 - Jan 14th, 2008, 1:31am
Just another relevant question: Is ESD structrure necessary for RF power amplifier? I am using "salicide block" (also referred to as drain extension) for ESD protection, but the drawback is loss of output power.
Reply #2 - Feb 4th, 2008, 12:35pm
Why dont you simulate  an ESD event on the PA and see what happens?
Suggest that you be fussy about including metal path RLC elements, ESD event will briefly have over 1-2 amps of current flowing.
probably a good starting point.
-- Jerry
Reply #3 - Mar 12th, 2008, 11:10am
Jerry -
Do you have a method for simulating ESD events you'd like to share?  :)
I've seen some people try to force current into a pin with a waveform that approximates the response they expect from an ESD event; I don't think this is a good approach.
Don't you need MOS models with snapback to get the right results?
-Geoffrey
SRF Tech
Arizona
Reply #4 - Mar 12th, 2008, 1:10pm
Geoffrey,
You are correct, without proper models simulating the ESD event is very difficult.  Not only do you need a proper snapback model but it must also account for other third-order effects such as thermal heating of diffusion, contacts and metal, as well as have accurate avalanche models if you want to capture the proper snapback trigger level.  No foundary I know offers this unless you work for TI, Freescale, or IBM and even then they keep most of their models locked up tight not to mention that the models are very layout specific so that if you have a layout remotely different from what was modeled, forget about the accuracy.  Some smaller foundaries do play with ESD models but I have rarely seen any that were very useful or accurate for general simulation.  There are new papers every year on ESD simulation models and nothing I have seen has become widely adopted or withstood the test of time.  (there were 6 papers proposing new modeling techniques just this past year at ESD/EOS symposium )
ESD events can be simulated relatively accurately if you are using an active BigFET design and the current densities per unit um are within model ranges of normal device operation...but this is an exception and not very good for an RF PA.
In the case of an RF PA, ESD can be a pain.  Using discrete ESD structures cost area and performance, so it is generally avoided.  Drain ballasting (in this case by using silicide blocking) as suggested by Faisal has a significant power impact as menioned so we always try to avoid it.  (though proper ballasting can be achieved without a power or headroom hit using specific layout techniques, but again only if your design can afford the layout approach which it may not).
Essentially, there is no one good approach for RF PA's, I have worked on 7 different PA's for 3 different applications and have used an almost entirely different approach for each one.  In somecases, depending on the process and the nature of the design, we had to take explicit steps to provide ESD protection, and in others, did not need to do anything at all because the PA process and layout itself was sufficient to protect it.
Faisal,
You need to know what the risk is for your PA in terms of snapback triggering, and thermal runaway.  The design itself maybe sufficient.  Since you are unsure, first go to your foundary and see if they can answer the question regarding the weakness to snapback of your driver device.  If they have no idea, you need to get a few sample devices of your PA (does not have to be your PA design but silicon using the same device in a similar layout) and test them using a TLP (transmmission line pulse) machine to study the health of the process.
Form that point you will need to decide what best to do for your ESD.
-Stephen
www.srftechnologies.com
Reply #5 - Mar 14th, 2008, 7:37pm
If you get a signal large enough to force a snapback situation on a transistor, you have probably already toasted the gate oxide, or fried a diode junction in a zener state. Agreed, what goes on in the MOS model is not going to be accurate.
***However*** what you are trying to do here is model the ESD protection network, and get the ESD transients under control. That set of structures is RLC and Diode element networks, with the intention of keeping the MOS devices within non-failure regions. You create an ideal element model of the JEDEC HBM and JEDEC MM, which are nothing more than a precharged capacitor, a switch and some resistance. Need to watch the error tolerances in the simulator, due to having 1KV to 5KV at one location, and under 1V elsewhere.
It's not beautiful,  :-? but it works.  :o If you have used IBM foundry (6SF, 7SF, 8SF, RFCMOS, 5HPE) or LSI Logic (G10, G11, G12 back when they did their own foundry) and used their ESD I/O's then you are going thru some ESD designed using this approach with good first time success. (and yes, I did those designs, or supervised the folks who did them)
Jerry
Geoffrey_Coram wrote on Mar 12th, 2008, 11:10am:
Jerry -
-Geoffrey
Reply #6 - Mar 17th, 2008, 12:50pm
loose-electron wrote on Mar 14th, 2008, 7:37pm:
This assumes the protection network is made up of diodes, and no GGNMOS or such, doesn't it?  OK, in this case, I believe you can simulate it.
Reply #7 - Mar 17th, 2008, 2:48pm
If you are using a MOS device, you need to use it in a non destructive manner, so that will fly. If you are using a specialty device lke a SCR, TRIAC or, a MOS device going into a "not between the power rails" situation, then you need to develop a model for that.
Faisal
Reply #8 - Mar 29th, 2008, 1:07pm
Thank you Jerry, Stephen and Geoffrey for your answers.
With the transistor models available from the foundry, it is not a possibility to simulate ESD events in Spectre. I would try with the another layout style, but will have to check with the foundry ESD experts on this subject.
Kind Regards,
Faisal Mateen.
