Jul 17th, 2024, 11:33pm
DCO Quantization Noise White Dithering (Read 3654 times)
neoflash
Mixed-Signal
Designer
Jan 12th, 2008, 6:56am
Hi, Folks:
I'm reading some papers on DCO.
One question I got is on white dithering of DCO. Basically due to limited frequency resolution, there is high quantization noise without sigma-delta modulation. White dithering is often used in this case.
1. I'm not sure that white dithering is using finer resolution, i.e. smaller capacitor, for random dithering or not. For example, if dithering word length is 4-bit, can I say that dithering LSB resolution is 1/16 of normal control bits?
2. If it is using smaller capacitor, why not directly use that in normal control bits, to lower the quantization noise?
Neoflash
rfmems
Re: DCO Quantization Noise White Dithering
Reply #1 - Feb 19th, 2008, 5:10am
dithering of DCO should always be on the smallest varactor
emad
Cairo, Egypt
Reply #2 - Mar 5th, 2008, 9:30pm
The idea is to have an infinitely small capacitance. The trick is to do that through time averaging of a larger cap. Of course this causes quantization noise and the smaller the dithered cap the lower the quantization noise.
Emad
neoflash
Mixed-Signal
Designer
Reply #3 - Mar 6th, 2008, 5:26am
emad wrote on Mar 5th, 2008, 9:30pm:
Emad
Yes, then I think the LSB cap in both dithering and regular control bits should be the same in size.
