Sep 4th, 2024, 10:19am
Bug in mtline (Read 3867 times)
setb2609
Bug in mtline
Jan 12th, 2008, 1:30pm
Hi there,
I seems that I found a bug in the mtline odel in mmsim 6.0 - here it is  just for the record ...
When I choose the FiledSolver (and sublossline) not the values for the loss tnagent are written into the netlist for "dloss" but instead the values for the "dielectric layer thickness" are just duplicated here - this results in some kind of shorting to ground in my case Wink
Anyway - if there are other known problems with the mtline-model in mmsim please let me know ...
setb2609
Re: Bug in mtline
Reply #1 - Jan 12th, 2008, 2:10pm
Oh - and if someone has a fix or workaround for this bug - so thar I  don't have to edit the netlist anymore - I would realy love to hear about it ...
setb2609
Re: Bug in mtline
Reply #2 - Jan 12th, 2008, 3:29pm
Furtheron I'm still wondering why the value of C11 in the rlgc file is - after calculation by the cadence field solver - is only about half the value as the one that I calculated by other tools for the same dimensions ?
Tawna Wilsey
Snohomish, WA
Re: Bug in mtline
Reply #3 - Jan 15th, 2008, 11:40am
The issue where mtline incorrectly generates netlist and rlgc file
is fixed in IC 5.10.41.500.4.59
It is not a spectre bug - it was actually netlisting bug in ADE.
I recommend upgrading your software to IC5.1.41USR5 and MMSIM (spectre) 6.2.1.
MMSIM (spectre) 6.0 is quite old.
If interested, you can email me and I will send you an appNote on mtline.  Alternately, you
can download it from sourcelink.cadence.com .
best regards,
Tawna
tawna@cadence.com
Tawna Wilsey
View Profile tawnaWilsey   IP Logged
