Sep 28th, 2024, 10:24am
About the channel legth modulation (Read 3352 times)
Richardyi
Jan 14th, 2008, 11:52pm
Why the factor of channel legth modulation is different for nmos and pmos? Even for the channel length.
Can anyone help me?
 Thanks.
vivkr
Re: About the channel legth modulation
Reply #1 - Jan 15th, 2008, 7:38am
The answer is contained in your question. For submicron transistors, saturation typically occurs due to onset of velocity
saturation rather than due to pinchoff of the channel. Naturally, as the mobility of electrons and holes is very different,
so is the onset of saturation and the related behavior.
Hope this answers your question.
Vivek
Richardyi
Reply #2 - Jan 15th, 2008, 7:22pm
Thanks for you answers.
But I still can not understand it.
For a Spice model, the channel length modulation parameter of NMOS is smaller than that of PMOS.
HdrChopper
Reply #3 - Jan 16th, 2008, 6:10pm
What Vivek stated is totally correct. Let me try to complete the whole picture by taking into account the following:
since the saturation velocity is the one driving the channel length modulation for sub-micron transistors and that the electrons mobility is larger than the pmos one, then the saturation velocity for the pmos will be smaller than the one for the nmos.
Therefore, under same bias conditions and geometry, it will be the pmos the one to get its channel modulated first. Hence, more susceptible to lenght modulation or equivalently larger modulation parameter.
Tosei
Keep it simple
vivkr
Reply #4 - Jan 16th, 2008, 11:19pm
Hi Tosei, Richard,
You need to be careful. The mobility of holes/electrons does not have a direct relation to the saturation velocity of the respective carrier in silicon although one might be inclined to think so.
I believe but I cannot find a suitable table anywhere that holes and electrons have almost similar values of saturation velocity in silicon.
As for why exactly you see more channel length modulation in your PMOS than in an NMOS, I could not offer an explanation at present. Perhaps someone else can.
Vivek
