Aug 16th, 2024, 5:15am
About the channel legth modulation (Read 3634 times)
Richardyi
Jan 14th, 2008, 11:55pm
Why the factor of channel legth modulation is different for nmos and pmos? Even for the channel length.
Can anyone help me?
 Thanks.
Re: About the channel legth modulation
Reply #1 - Feb 8th, 2008, 2:59am
Richard,
  In older processes, the bulk substrate concentration is different for
the n-channel and p-channel transistors. Usually one device is built
into well, while the other exists in the substrate. The well doping
needs to "counter-dope" the substrate doping and is typically ~10x
higher in concentration. As a result, the depletion regions change at
different rates with applied bias for n-channel and p-channel transistors.
The difference in the rate of change of the Drain-Bulk depletion region
is a significant contributor to the difference in the channel length modulation.
Berti
Reply #2 - Feb 8th, 2008, 3:34am
Hi Sheldon,
Quote:
In older processes,...
Is it diffierent for advanced processes?
Reply #3 - Feb 10th, 2008, 8:55am
Berti,
  It should be a reasonable first-order approximation.
