vivkr
Hello Achim,
My question was more general. So you are saying that AC switch levels will also work for STB and XF. In some ways, that's not so desirable. What about NOISE? Also AC? What about PSS? From what you mention, I would suppose that all these would also be configured as AC as one would normally do a PAC, PNOISE etc. after PSS.
Is there a good way to get around this and build a switch which can be custom closed for a given analysis, like sp1tswitch?
Regards Vivek
