tm123
Chicago, IL
I am interested in using Verilog to model some blocks in a PLL in order to do a closed loop PLL simulation. I am interested in the PLL settling, in particular the effect of cycle slipping. I would like to use Verilog to model the VCO and frequency divider. I plan on using the transistor level PFD, CP and loop filter. My questions are:
-Can a simulation be done in Spectre using the Analog Environment with transistor level schematics and Verilog code? -Is Verilog AMS the best tool to use, or are Verilog-A/VHDL more appropriate for the VCO/frequency divider respectively? -Does the Verilog code need to be imported into Cadence? If so, how is that done? -Is there existing documentation or papers that explain this type of simulation?
Thanks for your time.
Regards, Tim
