Sep 25th, 2026, 2:06pm
Using Verilog for PLL Closed Loop Sim (Read 3750 times)
tm123
Chicago, IL
Jan 17th, 2008, 4:20pm
I am interested in using Verilog to model some blocks in a PLL in order to do a closed loop PLL simulation.  I am interested in the PLL settling, in particular the effect of cycle slipping.  I would like to use Verilog to model the VCO and frequency divider.  I plan on using the transistor level PFD, CP and loop filter.  My questions are:
-Can a simulation be done in Spectre using the Analog Environment with transistor level schematics and Verilog code?
-Is Verilog AMS the best tool to use, or are Verilog-A/VHDL more appropriate for the VCO/frequency divider respectively?
-Does the Verilog code need to be imported into Cadence?  If so, how is that done?
-Is there existing documentation or papers that explain this type of simulation?
Thanks for your time.
Tim
Stefan
Re: Using Verilog for PLL Closed Loop Sim
Reply #1 - Jan 18th, 2008, 12:28am
Only with VerilogA, which would be uninteresting in terms of simulation speed.
VerilogAMS is very well suited for that type of simulation.
Use the Library Manager to add a verilog view to the corresponding symbols and use the hierarchy editor to switch between the views for simulation.
Yes. Check designers-guide or cadence documentation.
Stefan
View Profile 16731287   IP Logged
tm123
Chicago, IL
Reply #2 - Jan 18th, 2008, 8:45am
Hello Stefan,
Thank  you for replying, your answers help a lot.  One follow up question:
-Do I need to select the AMS plug-in in the hierarchy editor in order to simulate with Verilog AMS code?
Thanks again.
Tim
