Sep 28th, 2024, 2:27am
AB operation in a class-A amp??? (Read 2298 times)
vivkr
Jan 18th, 2008, 8:09am
I built a simple class-A amp with 2 stages, and each stage has its own CMFB. I am suprised to see that the output settles to the
maximum accuracy even when I go on reducing the time available for settling. It looks very good of course, but can someone
suggest why this might be happening?
Vivek
HdrChopper
Re: AB operation in a class-A amp???
Reply #1 - Jan 19th, 2008, 7:09pm
hi Vivek,
Is it the differential or output CM signal the one setting that fast? May be a drawing of your circuit might help better understand the behavior.
Tosei
Keep it simple
vivkr
Reply #2 - Jan 20th, 2008, 11:16pm
Hi Tosei,
It seems to only be the differential output. Unfortunately, I cannot post a drawing on my circuit because
I would get into trouble if I did that. However, I can describe the architecture.
2-stages, first stage with NMOS input, NMOS cascode. Compensation cap returns to cascode node.
Switched-cap CMFB for both stages separately so that compensation is simpler. This scheme has been
around in many different forms, and although I have added a CMFB in each stage, I believe that people have
also done this.
I will see if I can find out something from my side.
Vivek
