Jul 16th, 2024, 10:55am
input.scs: +8 is an instance of an undefined model (Read 8090 times)
dpx4086
Jan 20th, 2008, 1:41am
when i tried to make post-simulation using specte simulator with the extracted view (produced in DIVA), i got some errors in the spectre.out :
Error found by spectre in `stage1_rfpdk_sym_fordiva_extracted', during circuit
       read-in.
   input.scs: +8 is an instance of an undefined model dnwpw.
   input.scs: +7 is an instance of an undefined model dnwpw.
   input.scs: +6 is an instance of an undefined model dnwpw.
   input.scs: +5 is an instance of an undefined model dnwpw.
   input.scs: +4 is an instance of an undefined model dnwpw.
   input.scs: +3 is an instance of an undefined model dnwpw.
   input.scs: +2 is an instance of an undefined model dnwpw.
at the same time, here is the relative message in the input.scs :
   \+8 (IN VDD) dnwpw area=5.02139e-10 pj=0.00010794 m=1
   \+7 (GND VDD) dnwpw area=9.01648e-11 pj=3.902e-05 m=1
   \+6 (GND VDD) dnwpw area=5.6673e-10 pj=0.00025188 m=1
   \+5 (GND VDD) dnwpw area=2.5659e-10 pj=0.00011404 m=1
   \+4 (GND VDD) dnwpw area=1e-20 pj=1e-20 m=1
   \+3 (GND VDD) dnwpw area=1e-20 pj=1e-20 m=1
   \+2 (GND _7) dnwpw area=1e-20 pj=1e-20 m=1
what does dnwpw mean?
how to solve this problem?
thank you.
The only thing we have to fear is fear it self !!!
Re: input.scs: +8 is an instance of an undefined m
Reply #1 - Jan 20th, 2008, 5:55pm
dnwpw is the name of a model. It should be found in the model file (from the PDK).
aaron_do
Reply #2 - Jan 21st, 2008, 7:27am
I remember having an error like that before. I think dnwpw is a parasitic diode. You should find your diode model file and see if it has the same name. If the name is slightly different then it won't be recognized.
cheers,
Aaron
dpx4086
Reply #3 - Jan 21st, 2008, 7:29pm
thanks for your reply, Ken Kundert and aaron_do.
i can find the model of dnwpw_1p8 in the pdk models. but there is no model for dnwpw.
how could this dnwpw be produced since there's no model for him ?
aaron_do
Reply #4 - Jan 21st, 2008, 9:02pm
maybe you could make a copy of that model file, and rename the model dnwpw. Then in the analog design environment, use the modified model file for diodes...
that's assuming they are one and the same...
Aaron
dpx4086
Reply #5 - Jan 21st, 2008, 11:37pm
aaron_do wrote on Jan 21st, 2008, 9:02pm:
Aaron
hehe...i've tried this. and the result is S21 dropped from +3dB to -8dB. i'm not sure whether it is normal.
