Sep 17th, 2024, 11:21am
Amplitude of noise processes (Read 2783 times)
Stefan
Jan 22nd, 2008, 2:46am
I'm kinda confused with noise processes Smiley
When looking at Chen's "paper Modeling RF Systems",
noise voltage is added as white_noise(pwr,'name'), where
pwr equals (NF-1)*4*K*T*R
Does anyone know how to calculate the voltage AMPLITUDE of the white_noise function at a time t ?
(yes, I know that it's a random process)
I'm trying to implement the white_noise function using a dist_normal process where I can't provide any power argument ...
Stefan
View Profile 16731287   IP Logged
Frank Wiedmann
Munich, Germany
Re: Amplitude of noise processes
Reply #1 - Jan 22nd, 2008, 5:52am
The rms noise voltage equals the standard deviation of the normal distribution.
Jess Chen
California Bay Area
Reply #2 - Jan 22nd, 2008, 7:52pm
Stefan,
You can compute the standard deviation (i.e. rms noise) of the noise from the noise figure and sample rate. If you are using a baseband equivalent model and the expressions I give in my paper, you need to use half the sample rate as the bandwidth when computing the standard deviation. You should also use $rdist_normal instead of $dist_normal. The "r" gives you a random real number. Without the "r" you get integers.
-Jess
