Sep 27th, 2024, 10:21pm
PNoise analysis of PFD+Charge pump (Read 3578 times)
nandy
Timbuktu
Jan 24th, 2008, 4:31am
Hello people
I need to find the phase noise contributed by a phase/frequency detector + charge pump combination which are part of a frequency synthesizer. When the synthesizer is locked, both the inputs to the PFD are of the same frequency and hence the beat frequency is zero (albeit there will be reference feedthrough). But I cannot do a PSS/Pnoise analysis with a 0 beat frequency. How do I proceed?
I tried measuring phase noise while having a finite frequency difference too, but the simulation never seems to converge however much I change the tstab value or if I make it conservative or liberal. BTW I use cadence spectre's analog environment for the simulations.
Thanks in advance
Frank Wiedmann
Munich, Germany
Re: PNoise analysis of PFD+Charge pump
Reply #1 - Jan 24th, 2008, 5:57am
"Beat frequency" is a bit of a misnomer, "fundamental frequency" would probably have been a better choice. Simulate your circuit in the locked state and enter the lowest frequency in your circuit as "beat frequency" (or the longest period as "beat period").
nandy
Timbuktu
Reply #2 - Jan 24th, 2008, 7:40am
But Frank, since charge pump is shaped by the low pass filter in the loop, wont I be interested in noise near DC rather than at the reference frequency (since reference frequency is many times higher than loop bandwidth, and any noise at these frequencies will be suppressed anyway)?
Frank Wiedmann
Munich, Germany
Reply #3 - Jan 24th, 2008, 11:12pm
You can do an absolute frequency sweep in the pnoise analysis and examine the noise at any frequency you like.
nandy
Timbuktu
Reply #4 - Jan 24th, 2008, 11:37pm
OK. I'll try that. Thank you Frank.
