Sep 4th, 2024, 6:14am
Baud Rate ADC for SerDes, adequate? (Read 4460 times)
neoflash
Mixed-Signal
Designer
Jan 26th, 2008, 3:46am
TI published a paper on 12.5G SerDes with baud rate ADC. My question is that 1x sampling rate will have aliasing and minimum sampling rate should be 2x data rate. How could baud rate ADC  achieve clock data recovery?
didac
There's a million
ways to see the
things in life
manresa,spain
Re: Baud Rate ADC for SerDes, adequate?
Reply #1 - Jan 27th, 2008, 7:45am
If the paper is:"A 12.5Gb/s SerDes in 65nm CMOS Using a Baud-Rate ADC with Digital Receiver Equalization and
Clock Recovery", the title says all:they do the synchronization with DSP, look at the reference [5]:K. Mueller, M. Muller “Timing Recovery in Digital Synchronous DataReceivers” IEEE Trans. on Communications, pp. 516-531, May, 1976. This kind of algorithm if I remember correctly it's based in adaptative convergence, the speed of convergence usually is dependant if you use NDA(Non-Data Aided),DA(Data Aided-->syncronization data sent with the signal and known) or DD(Decision Directed, it decides what symbol it received and adjust following this decision and so on).
Hope it helps,
