Aug 16th, 2024, 6:17pm
defining user waveforms and functions in Cadence (Read 2396 times)
sutapanaki66
Jan 29th, 2008, 9:03pm
I recently had to make a transition from Mentor's Eldo to Analog
artist for analog simulations. I used to work a lot in eldo with user-
defined waveforms. The command there is .defwave <name> <expression> -
basically you get the idea, one can define new waveforms from existing
waveforms by putting them in some sort of an expression. This can be
nested further to define waveforms based on already defined waveforms
or mixing user-defined waveforms with waveforms coming directly from
simulation like V and I.
I was wondering is there such a possibility in analog artist? It being
a widely used simulator I just can not imagine that there is nothing
there for such a useful thing, so may be I just don't know it.
So, I'll appreciate a lot any suggestions and they'll be also of great
help.
Frank Wiedmann
Munich, Germany
Re: defining user waveforms and functions in Caden
Reply #1 - Jan 29th, 2008, 11:31pm
You can define equations in the "Outputs -> Setup..." form, most easily by getting the expressions from the calculator. I don't think that it's possible to nest expressions, though.
sutapanaki66
Reply #2 - Jan 30th, 2008, 11:59am
Is it possible to write expressions in a file which then I can include in the simulation? I assume there should be also some specific syntax when writing?
