Aug 15th, 2024, 9:38pm
ddt during ac analysis (Read 4065 times)
king
Feb 08th, 2008, 6:36am
I'm new to ac analysis in Verilog.
Models in Verilog has
Q = ddt(q)
I(p,n) <+ Q
What happens to ddt(q) during an ac analysis?
Can I display the value of Q as a function of f
by strobing Q while running an AC?
thanks.
Re: ddt during ac analysis
Reply #1 - Feb 8th, 2008, 2:55pm
ddt() effectively gets replaced by jω in an AC analysis. You cannot strobe during an AC analysis because the model is not actually executed during the AC analysis. Rather it is evaluated during the preceding DC analysis and linearized.
king
Reply #2 - Feb 12th, 2008, 4:34am
Thanks Ken.
In your varactor example, how will I then
check the frequency characteristics of q, ddx(q)
and i(p,n)?
Reply #3 - Feb 12th, 2008, 12:04pm
I don't understand your question.
king
Reply #4 - Feb 13th, 2008, 4:24am
after an ac analysis, the only outputs are the
Re and Imag parts of node currents and voltages
as a function of frequency.
how can i output other variables like
capacitances as a function of frequency?
in varactor, for example,
how can i extract dq/dV as a function of freq?
Reply #5 - Feb 13th, 2008, 9:14am
Isolate the capacitor, drive it with a voltage source that has an AC magnitude of 1, and plot its current. The current will equal the admittance. Divide by jω to get the capacitance.
