tm123
Chicago, IL
I am having some trouble running a very basic simulation using spectreVerilog through the hierarchy editor/analog environment. The testbench consists of 2 logic gates, one using a Verilog-XL view and one using a transistor level view. I can successfully run a DC simulation and I can see the resulting node voltages are correct. If I try to run a transient simulation, I see the following error in the spectre.out window: 'Error found by spectre during initialization. Error while starting attached simulator.' Also, my understanding is that a second verilog.log window should pop up when running the transient simulation, but I do not see this window (it does not pop up after a DC simulation either). I have verified that I have selected spectreVerilog as the simulator, and that the proper libraries and design variables are set correctly. I also verified that the paths to verilog.vmx and verilog.exe are set correctly. Any help with this issue to get a transient simulation started is greatly appreciated. Thanks in advance.
Regards, Tim
