spitalny
I have some BSIM3 spice models intended for use with ELdo. There are some parameters in the models that my simulator does not recognize. So, I am trying to understand what the paramters are and see if my simulator just has a different name for the same parameter, or not!
Here they are: 1) flkflag this appears i n the beginning of the mod model file 2) pg has something to do with source/drain diodes I think 3) dcaplev has something to do with source/drain diodes I think 4) alev also has something to do with source/drain diodes I think
If yo uknow anything that could help it would be greatly appreciated! Also, if you know of any good online version s of the Eldo user mnaul/mode manual that would be tremendously helpful!
Thanks! P.
