Sep 18th, 2024, 7:16am
Comparator's linearity for SAR ADC (Read 3368 times)
Leila
Feb 14th, 2008, 2:57pm
My intention is to design a comparator, I choose the NMOS Diff amplifier with  PMOS load and used the resistor CMFB, for my ADC precision I need to get a gain about 32. I sweep the input common mode with the range between 300mV and 600mV, then I see 25% variation in circuit gain for this sweep in input.
I force all transistor to work in subthreshold, I know the short channel effect makes to reduce the gds, I tried to remove the change in the current tail now I get the 5% change in gm compare with 18%. But still could not see constant gain. Sounds that I am not in the right way.
Is there any way to make the gain for different input common mode approximately constant?
Or I should not worry about the linearity and if in the worse-case I get enough gain and for the rest more gain that will be fine for my ADC?
Please Advice,
vivkr
Re: Comparator's linearity for SAR ADC
Reply #1 - Feb 14th, 2008, 11:00pm
I would just try to make sure that the comparator has enough gain in the entire range of interest. The comparator
should have enough gain to amplify a relatively small signal into fullscale logic levels (when a latch is included)
And this should be done within the available time.
Vivek
fonseca.ha
UK
Reply #2 - Feb 15th, 2008, 5:18am
Hi
If the input common mode can be as small as 300mV it seems that an NMOS differential pair may not be the best solution. I think that the current source that bias the differential pair may be without headroom. what is the value of your sypply? can you consider using a PMOS diff pair?
Humberto
vivkr
Reply #3 - Feb 15th, 2008, 6:22am
fonseca.ha wrote on Feb 15th, 2008, 5:18am:
Hi
Humberto
Or you can use a capacitively coupled comparator. The input common mode levels are freely chosen by you to optimize performance. The input common mode variation
goes out of the picture completely. So your original problem does not exist here anymore.
Vivek
