Leila
Hi, My intention is to design a comparator, I choose the NMOS Diff amplifier with PMOS load and used the resistor CMFB, for my ADC precision I need to get a gain about 32. I sweep the input common mode with the range between 300mV and 600mV, then I see 25% variation in circuit gain for this sweep in input.
I force all transistor to work in subthreshold, I know the short channel effect makes to reduce the gds, I tried to remove the change in the current tail now I get the 5% change in gm compare with 18%. But still could not see constant gain. Sounds that I am not in the right way. Is there any way to make the gain for different input common mode approximately constant?
Or I should not worry about the linearity and if in the worse-case I get enough gain and for the rest more gain that will be fine for my ADC?
Please Advice, Thanks
