Berti
I think there is a bug in your test-bench. Just a guess: Probably you calculated the GBW directly from the output signal (with calculator from Cadence?). When you take the differential output you get twice the signal amplitude compared to the single-ended case. Thus, the GBW will double, too. You should make sure that the input signal is equal 1V AC in differential and single-ended case.
