TF_electronics
Hey all,
I want to measure small resistor variations (0,1 up to 3 ohm). I started testing with a constant current source of +/-1A (i used a LM117), the results are do-able but have to be better. To measure i use a national instruments PXI 6040E - DAQ card.
As you know the (test)wires do allso have an resistor value
Maybee one of you hase the answer. ::)
