John O Donovan
San Jose, CA
How about pausing the simulation process using "kill -STOP" and then resuming it later. With Spectre, when it gets the STOP signal, it will return it's licenses and then retrieve then when it get the CONT signal. This is normally used in an LSF flow where a higher priority jobs needs to get a license, but none is available.
John
