Jul 18th, 2024, 10:01pm
Monte Carlo Model Selection (Read 2153 times)
rajath
Feb 26th, 2008, 1:09am
I plan to run a monte carlo analysis on a circuit for mismatch, and when I checked the model files, there seem to be two sections I can choose from: mc and stat. What exactly is the difference between these two models? Appreciate any help!
regards,
rajath
bernd
Munich/Germany
Re: Monte Carlo Model Selection
Reply #1 - Feb 26th, 2008, 6:31am
The stat section 'statisics block' specifies the statistical distribution,
process variation. It defines which parameter and how should be varied through
a Monte Carlo simulation.
The mc section then should include the transistor model with the parameters
to vary.
Best is to check yourself your model file.
Bernd
Just another lonesome cad guy
bernd
Munich/Germany
Reply #2 - Feb 26th, 2008, 6:38am
Parallel or at least related thread.
http://www.designers-guide.org/Forum/YaBB.pl?num=1203976519
Bernd
