Jul 18th, 2024, 1:22pm
PDK install in IC610 (Read 2293 times)
jimwest
Feb 25th, 2008, 5:33pm
Hi folks,
  I am stucked while installing the pdk in IC610.
Is IC610 compatible with the pdk which is not an open access one?
I searched the menu in CIW and found out there is an OA translator.
But I failed to open the library by applying the translator.
Is there any solution?
Kindest Regards,
Jim
Frank Wiedmann
Munich, Germany
Re: PDK install in IC610
Reply #1 - Feb 26th, 2008, 12:01am
As far as I know, IC610 only exists for OA. I see three possible solutions:
  • Use IC5141.
  • Ask your foundry if they have a PDK for OA.
  • Ask Cadence support for help if you have problems with the translation.
