Jul 18th, 2024, 11:28am
How to calculate the comparator's offset? (Read 3167 times)
streeter
Feb 29th, 2008, 3:04am
How to estimate the comparator's offset?
HdrChopper
Re: How to calculate the comparator's offset?
Reply #1 - Feb 29th, 2008, 7:14am
Hi
In case you are trying to simulate it, please see http://www.designers-guide.org/Forum/YaBB.pl?num=1204012103. It might shed some light on what you are looking for.
Tosei
Keep it simple
streeter
Reply #2 - Mar 2nd, 2008, 5:16pm
Thanks!
But I want to estimate the offset before simulation.
How to do it?
vivkr
Reply #3 - Mar 2nd, 2008, 10:56pm
Typically, the offset of a well-designed comparator is dependent largely on the mismatch between the 2 input transistors.
Mostly, the threshold voltage mismatch of the 2 transistors gives you information about the offset directly.
You can get this data from your process doc. If the gain of the first stage (assuming multiple gain stages are present) is not
large enough (< 10 say), then the load devices in the first stage may also contribute. But for rough estimation, I would just
use the threshold voltage mismatch. It works for me. Hopefully, it works for you too.
Vivek
