Jul 18th, 2024, 11:17am
nominal run in Monte-Carlo (Spectre) (Read 2385 times)
parth_sv
Feb 29th, 2008, 6:36am
Hi All,
  Is there a way to prevent Spectre(ADE) from running nominal run when I am running Monte-carlo Analysis?  There is an option called 'donominal' which when set to 'no' does the above - however such option is available only in command line and I dont fnd that in Monte-Carlo GUI.
Thanks in Advance,
Partha
HdrChopper
Re: nominal run in Monte-Carlo (Spectre)
Reply #1 - Mar 3rd, 2008, 4:55pm
As far as I knew, although the defaults settings in the Spectre ADE for the Monte-Carlo analysis are in "nominal", this analysis did not run such nominal corner but one according to the Monte-Carlo parameters that should be loaded in the Model files section.
Tosei
Keep it simple
