Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jul 18
th
, 2024, 1:23pm
Home
Help
Search
Login
Register
PM to admin
Simulators
Circuit Simulators
› Re-running particular monte-carlo run
Previous topic
Next topic
Re-running particular monte-carlo run (Read 2391 times)
parth_sv
Feb 29
th
, 2008, 5:06am
Hi All,
I am currently running a monte-carlo simulation for a sub-block. I need to take the worst case of the 'N' runs and use that particular monte-carlo run(Vt variation say) at higher-level(more blocks put together) to check the total effect. How can I save that particular run and use it in different spectre run?
Thanks in Advance,
Partha
IP Logged
achim.graupner
Re: Re-running particular monte-carlo run
Reply #1 -
Mar 3
rd
, 2008, 3:04am
Hi Partha,
once you have identified your worst case run, use this number in the field "First Run" and "number of Runs" 1, This repeats this single simulation and allows further analysis.
Achim
Achim Graupner
ZMD AG, Dresden, Silicon Saxony, Germany
IP Logged
Frank Wiedmann
Munich, Germany
Reply #2 -
Mar 3
rd
, 2008, 3:34am
I also like to use this method. However, I don't think it can be used in his case because it only works if the circuit is not changed and he wants to use the results in a larger circuit.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
»» Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
