Jul 18th, 2024, 7:22am
Transient Sensitivity in Spectre (Read 3884 times)
Christoph
Feb 29th, 2008, 10:00am
Dear All!
Why is there no tranisent sensitivity in spectre? I've made a delay measurement with spectreMDL and want to find the sensitivity of this delay to some circuit parameters. Is this possible in spectre?
Thanx!
Christoph
Stefan
Re: Transient Sensitivity in Spectre
Reply #1 - Mar 1st, 2008, 2:35am
I don't think that there is something like "transient sensitivity".
You could do a transient simulation, save the operating point at a desired time and then use an ac (sensitivity) analysis.
View Profile 16731287   IP Logged
HdrChopper
Reply #2 - Mar 5th, 2008, 6:02pm
Hi Christoph,
Actually worst casing for transient simulation is somehow a "transient sensitivity" analysis. You should be able to change your model parameters and see the effect on the transient analysis, in particular in the delay you are interested in.
Tosei.
Keep it simple
Christoph
Reply #3 - Mar 5th, 2008, 11:26pm
Hi!
Thank you all for your answers. Changing parameters by hand would work but is rather inefficient when there are many parameters. An adjoint sensitivity calculation would be good.
Anyway, thanks for your help.
Kind regards,
Christoph
HdrChopper
Reply #4 - Mar 7th, 2008, 5:36pm
You could still save some time if you run your transient analysis with an ocean script. You should write one in which you run each transient analysis for the set of values for each parameters you would like to change.
Hope this helps
Tosei
Keep it simple
