Jul 18th, 2024, 5:17am
Automatically calculating AD, AS, PD, PS, etc (Read 3605 times)
RobG
Bozeman, MT
Mar 10th, 2008, 8:35pm
I know this can be done easily, but I can't seem to get to first base.
When I place a mosfet using the cadence schematic capture tool, and give it a certain width, I would like the AD, AS, parameters automatically filled out (even if I have to use simplified formulas).  I know there must be a file somewhere where you define these based on the width.  Can someone direct me to this file or give me a hint one what I should be searching for in the help?
Re: Automatically calculating AD, AS, PD, PS, etc
Reply #1 - Mar 11th, 2008, 8:35am
To compute the value, you need to know the diffusion dimension perpendicular to the width (note: it's not the gate length).
Are you asking how to get that value?  Or are you asking how you set up the Cadence CDF (component ... form) with a callback so it fills in the values automatically?  (Change the width, callback changes AD and AS.)  Or are you wanting to change your netlister to print out a default AD=value if there's no value specified in the form?
RobG
Bozeman, MT
Reply #2 - Mar 11th, 2008, 9:15am
I know the formulas and diffusion dimensions; I just need to set up the CDF that will fill the values automatically, e.g. AD=w*0.4u.  Right now I'm filling out the form by hand.  Your help would be enormously appreciated!
Reply #3 - Mar 11th, 2008, 10:19am
You'll have to search the directory tree for your PDK -- though perhaps CDS.log will give you some hints.  You're looking for files ending in .cdf, they're written in skill.
RobG
Bozeman, MT
Reply #4 - Mar 11th, 2008, 3:44pm
Thanks for the hints - they help a lot.
Another person pointed out that it can be done with iPar("w") in the CDF.  This is much easier.
