Aug 18th, 2024, 3:35am
op amp topology (Read 6428 times)
aaron_do
op amp topology
Mar 04th, 2008, 12:33am
i need to design a simple differential op amp which is able to drive a resistance of about 2K with a unity gain bandwidth of at least 100 MHz and as low power as possible. Any suggestions on a topology?
thanks,
Aaron
HdrChopper
Re: op amp topology
Reply #1 - Mar 5th, 2008, 2:47am
One simple approach would be to use a folded cascode amp to maximize GBW, stabilized with a Miller second stage. This one could be an AB output stage to save some power an at the same time to have enough current driving for your 2K load.
This would be at least a starting point.
Hope this helps
Tosei
Keep it simple
vivkr
Re: op amp topology
Reply #2 - Mar 5th, 2008, 2:57am
Hi Aaron,
I would use some kind of a class-AB topology. There are several out there, some using 2 stages + an AB, some purely AB. If you do not need
very large gain and noise is not very critical, try out: "Lopez-Martin et al" from JSSC, May 2005. Of course, there are several other possible
solutions in AB, all very good. I just know these ones because I was playing around with them and was able to make these very simply. They also
don't need any overhead circuitry. If you look carefully, you will find ways to reduce the power consumption even further, particularly with
Topology # 1 in this paper where 2 branches are redundant. Just search around for more if you like.
I would keep it simple.
Vivek
vivkr
Re: op amp topology
Reply #3 - Mar 6th, 2008, 12:17am
Hi Aaron,
I was just trying something out and I think that maybe the opamps in that paper I mentioned aren't the best for you as the gain would be rather average
with them (40-50 dB). They are better suited for driving cap loads. If you need more gain, try using a 2-stage or so topology with a class-AB stage.
There are several good examples of those in the literature and even in textbooks. Push-pull from Gray & Meyer would do well at the cost of some headroom.
Vivek
fran2k5
Re: op amp topology
Reply #4 - Mar 7th, 2008, 9:45am
if you have enough supply you could try to boost the gain of the first stage with a telescopic configuration and use a second stage like in Miller opamps. If the gain is enough you could let the resulting OTA drive the 2K resistance w/o output stage.
Hope this helps.
frank
aaron_do
Re: op amp topology
Reply #5 - Mar 8th, 2008, 4:10am
Thanks for all the replies.
There are a few problems. I actually need a fully differential op amp. And yeah it needs to drive a resistive load. voltage headroom is 1.5 V, so i don't know if that's enough to design a telescopic op amp. So far I've been going with a simple two stage op amp. The gain is only around 30 dB when driving a 2kohm load so I definately need to boost the gain. Its already using about 400 uA so i want to avoid increasing the power consumption...
I chose 2 kohm based on the noise requirement, but I think I may need to simply increase the load resistance if i can't boost the gain any other way.
cheers,
Aaron
vivkr
Re: op amp topology
Reply #6 - Mar 10th, 2008, 12:09am
aaron_do wrote on Mar 8th, 2008, 4:10am:
Hi Aaron,
Why do you need to drive a resistive load, especially since you mention that you are able to choose it freely (based on noise requirements)? Are you making
the next stage as a resistive differential amp? Surely you have considered all the tradeoffs involved to size the R-load to a maximum.
If possible, I would recommend using a class-AB output stage with your 2-stage opamp. That might get you what you need.
Vivek
Berti
Re: op amp topology
Reply #7 - Mar 10th, 2008, 1:04am
Hi Aaron,
I agree with the other respones that a class-AB buffer will be a good solution. Because driving 2kOhm with an OTA you
just sacrifice gain. However, be aware of interference when using class-AB buffer.
Whether you can use a telescopic OTA or not depends on the requirements on signal-swing. I use telesopic
amplifiers at 1.2V supply (small output-swing).
aaron_do
Re: op amp topology
Reply #8 - Mar 11th, 2008, 6:31am
I'm designing an active-RC filter. Increasing the 2 kohm resistor increases the noise while reducing the requirements on the opamp. Anyway i ended up designing two different opamps. The first stage opamp is very power hungry but provides good gain. That allows it to drive the 2kohm and reduce the effect of the noise of the following stages. So the following stages all use very low power op amps.
I think i will end up going with a telescopic op amp and i'll look into the output stage. Thanks for all the help,
cheers,
Aaron
