ACWWong
LO feedthru can be due to dc offset in your mixer. check your layout for systematic offsets and run some monte-carlo simulations. Another major source will be crosstalk, be it in the silicon or in the package. Good layout planning (i.e having tx output bodnwires perpendicular to the lo carrying (the LO itself or LO supply) bondwires should help
If you have access to dc bias points, triming dc offset can reduce the leakage to crosstalk induced leakage.
Also when you say 5 degree mismatch, what do you mean ? duty cycle ? this can be improved by improving oscillator design and layout. it usually higher level harmonics or crosstalk non-symmetry which impacts fundamental duty cycle.
cheers aw
