Sep 17th, 2024, 7:37pm
Advantage of using Div-2 Frequency Dividers (Read 5173 times)
cubalex
Mar 07th, 2008, 1:41am
Hello everybody,
I'm wondering if it is desirable to design a  frequency divider for a frequency
synthesizer PLL only with 2^n dividers.
Are there any advantages (speed, power dissipation, easy implementation in CMOS,
noise,...) in avoiding digital counters or other non divide-by-two blocks?
Thanks in advance!
Alex
Re: Advantage of using Div-2 Frequency Dividers
Reply #1 - Mar 9th, 2008, 11:25pm
Sure it is easy to implement a 2^n divider. And a simple implementation often means lower power. However, what divider you need depends on the application and spec.
Best regards,
Yawei
vivkr
Reply #2 - Mar 10th, 2008, 4:02am
Be aware that using 2^n counters (asynchronous %2 counters) will result in more phase noise as opposed to using synchronous counters.
The price you pay for synchronous counters is of course more, much more power.
Vivek
Berti
Reply #3 - Mar 10th, 2008, 4:34am
Hi Vivek,
when using an asynchronous counter, you can synchronize the divided output with the
input clock using a single flip-flop. In this way, only this single flipflop will contribute to jitter/phase noise.
vivkr
Reply #4 - Mar 11th, 2008, 11:53pm
Berti wrote on Mar 10th, 2008, 4:34am:
Hi Vivek,
Of course !!! Thanks for correcting this omission in my post.
Vivek
cubalex
Reply #5 - Mar 13th, 2008, 2:03am
thank you for your replies.
In my case I have the option to use a standard TCXO with a divider value of
217 or a not-so-standard TCXO with a divide-by-32 (five divide-by-2 dividers).
If I got it right, it is worth using the not-so-standard TCXO for the advantages
of a divide-by-2 elements.
To put it in a nutshell, a divide-by-2 offers
- higher speed
- low power dissipation (async divide-by-2)
- smaller size
- easier implementation
in contrast to counters.
The disadvantage of jitter noise accumulation through async dividers can be
eliminated by synchronizing the last flipflop with the clock.
Alex
Berti
Reply #6 - Mar 13th, 2008, 11:40am
A divide-by-2 also ensures a duty-cycle of 50%.
Often this is the main reason for (at least one, final)
divide-by-2.
