aaron_do
i'm designing an active RC filter. I have not yet added compensation to the opamp, but I was wondering if there is any need to. The op amp is after all used in a filter where the caps and R's determine the phase shift and gain in the closed loop. So anyway my second question is, is there a way to do a closed-loop stability check?
thanks, aaron
