Aug 15th, 2024, 9:36pm
Verilog-A to C Compiler (Read 789 times)
rajdeep
UK
Mar 18th, 2008, 10:08pm
Is there any free version of a compiler that translates Verilog-A to C?
If any please let me know.
Thanks in advance,
Rajdeep
Re: Verilog-A to C Compiler
Reply #1 - Mar 19th, 2008, 6:00am
There's a SourceForge project "ADMS" that converts Verilog-A to XML and then to C.  The XML to C part requires you to have a special script that defines the API for the simulator you're expecting to link to.  There's a free simulator "zspice" that is supposed to work with ADMS, I forget if you have to install it also or if ADMS comes with that script; if ADMS has the script, then you could generate the C output if that's all you wanted, and not link it into zspice.
http://sourceforge.net/projects/mot-adms/
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Reply #2 - Mar 19th, 2008, 2:03pm
ADMS is geared towards compact modelling and will not understand all Verilog-A constructs, though. If I recall correctly, it does not support events other than the global events (initial_step and final_step). But correct me if I'm mistaken...
Cheers,
Marq
Reply #3 - Mar 20th, 2008, 6:17am
Of course, Rajdeep didn't say anything about why he wants the compiler.  If you want events to be handled, then you must have some plan to incorporate the output in a simulator, and you'd better get the Verilog-A compiler that generates object files for your simulator.  And, of course, ADMS is open-source, so you're free to add support for whatever you want. Smiley
My guess was that he was interested in taking, say, the Verilog-A code for a compact model and converting it to C, with begin/end changed to braces, etc.
