Jul 17th, 2024, 4:18pm
how to measure Q of an inductor in cadence? (Read 10330 times)
mike_ok
Mar 19th, 2008, 1:01am
Hi, everyone!
Smiley
this is my first time to start new topic and i hope that some will help me.
my questions is that in cadence evironment, how to measure the qulity of inductors and its inductance.
as is well know that the expession"Q=[Im(1/Y11)]/[Re(1/Y11)]" and "L=[im(1/Y11)]/[2*pi*freq]" in ADS environment can solve my questions, but in cadence,i don't know how to write the above exprssion, because i cannot find the term of Y11.
your help will be aprreciated!
thanks!
Re: how to measure Q of an inductor in cadence?
Reply #1 - Mar 19th, 2008, 1:54am
Frank Wiedmann
Munich, Germany
Reply #2 - Mar 19th, 2008, 3:22am
You should also be aware of the fact that there exist different definitions for the quality factor of an inductor. Depending on your application, some of them may be more useful for you than others. Please see http://www.simics.tec.ufl.edu/papers/00705364.pdf for details.
mike_ok
Reply #3 - Mar 19th, 2008, 5:08am
thank you for your replies!
now i still not know the details on how to implemet the term"y11", in my CIW, it says "y11,an unbound varication"
or some one give me more details on mearsure the Q and L?
Thanks a lot ,my dear friends!
ACWWong
Oxford, UK
Reply #4 - Mar 19th, 2008, 6:13am
after you have run an sp analysis y11 is available as:
yp(1 1 ?result "sp")
you can easily use the calculator to access these, more details will be in the cadence documentation.
also note as shown in the example given by pancho_hideboo, you'll need xval() to get the frequency term.
RFICDUDE
Reply #5 - Mar 19th, 2008, 4:20pm
A simple simulation technique is to use a 1A AC current source (DC=0A) across the inductor then you can measure the impedance of the inductor directly as the AC voltage across the inductor.
Z=re(Vac)+j*imag(Vac)
Y=1/Z
I like to look at all of these parameters when evaluating integrated inductors
Rs(f) = re(Vac)
Rp(f)=1/re(1/Vac)
Q(f)=imag(Vac)/re(Vac)
L(f)=imag(Vac)/(2*PI*xval(Vac))
mike_ok
Reply #6 - Jun 26th, 2008, 11:37pm
thank you, your methody is great! Smiley
