Jul 2nd, 2025, 12:30pm
cheap programmable divider (Read 2473 times)
vivkr
Mar 28th, 2008, 8:15am
I was wondering if there was a good way to make a cheap programmable resistive divider, say 6-8 bit?
Vivek
HdrChopper
Re: cheap programmable divider
Reply #1 - Mar 30th, 2008, 3:01pm
Hi Vivek,
I think the trade off between achieving such resolution and making a cheap resistor divider is (and I'm sure you know it)  the R-2R ladder structure.  You would need 2^N taps (N= number of bits) and your divider would only have unit cells of size R. Making a straightforward resistor divider by using equally sized resistor for each tap would require much more parallel/series combination for such resolution than the ones you need for the R-2R structure.
Hope this helps
Tosei.
Keep it simple
vivkr
Reply #2 - Mar 31st, 2008, 11:08pm
Hi Tosei,
Thanks for your reply. Indeed, the basic tradeoff is clear. I need to see if I can use an R-2R ladder. I
think this will be a problem for me because I need to keep the overall ladder resistance more or less
constant (not too much variation).  Perhaps I can try some variation on this one.
Vivek
