Aug 17th, 2024, 10:19am
Question about Vdd/2 reference voltage (Read 4054 times)
gaom9
CHINA
Apr 04th, 2008, 7:19am
I have a basic question about the Vdd/2 reference voltage.
In many design, the Vdd/2 voltage will be used as the common voltage. But how we can get the voltage?
Can we just use the same resistors in series or the same MOSFET in series to divide the Vdd to two parts? Or we should get it in other ways.
Thank you.
Best regards.
View Profile gaom9   IP Logged
adesign
Re: Question about Vdd/2 reference voltage
Reply #1 - Apr 7th, 2008, 9:27pm
It depends on the application requirements.
Sometime, two resistors in series also solves the purpose. You could also use Unity gain buffer followed by these resistors output.
Reply #2 - Apr 8th, 2008, 3:03pm
resistors will be more accurate, less process variance and bias sensitivity, with better matching
Berti
Reply #3 - Apr 9th, 2008, 12:27am
About this kind of question I was also thinking about several times.
As the common-mode usually doesn't draw static/differential-current, there is no need for a buffer.
But is it better to use resistors or transistors for the voltage divider?
Resistors show better matching, but usually the common-mode voltage doesn't need to
be very accurate. On the other hand, I think that two diode connected transistors will provide
more current when the common-mode voltage leaves the middle point. Therefore providing a more
stable voltage with lower quiesent current compared to two resistors where the current is always constant.
What do you think?
Reply #4 - Apr 10th, 2008, 1:32pm
if accuracy is important - 2 polysilicon resistors
if area is important - 2 triode driven FET's as a voltage divider
I would never use two diode connected devices stacked power to groud because the current changes so much over PVT variables. Diode connected devices driven by a current source can make for useful Vthreshold proportional references however.
As part of a larger chip, use a bandgap driving a V to I converter and use the I generated to create your reference voltages (across a resistance )to anything you want.
Its a really basic question but the "right answer" depends a lot on the specifics of what you are trying to do.
gaom9
CHINA
Reply #5 - Apr 11th, 2008, 6:30am
Thank you, everyone.
Yes, it is a basic question.
I think the resistors will word better than the diode connected mosfet, and easy to come out.
Best regards!
