Jul 18th, 2024, 3:32am
impedance measurement problem (Read 2800 times)
Pavel
Lausanne/Switzerland
Apr 14th, 2008, 7:02am
For my simulation I need to modelize my block as blackbox.
In order to measure interface pin impedances, I used Z-parameter measurement technique provided by Eldo (the same thig exists also in Spectre) and based on AC analysis.
From this measurement I extracted equivalent schema of my blackbox - R(Vin) and C(Vin) in parallel.
Then I did DC analysis of this blackbox. From this analysis I've get also R(Vin).
Once compared the results of 2 analysis - AC and DC, I discovered that R(Vin) is different in each case.
Where is my error?
Thanks in advance.
Pavel.
didac
There's a million
ways to see the
things in life
manresa,spain
Re: impedance measurement problem
Reply #1 - Apr 15th, 2008, 6:57am
Not sure about this one, but how do you know it's an error? I think that you have a frequency dependant impedance, so it's not strange to have a real part different in AC an in DC. Probably the simple R in parallel with C isn't suitable and you need a more complex lumped model to capture the behaviour, or if you are interested only on a limited set of frequency you must calculate the R and C for each frequency and use a different parallel for each sim.
Hope it helps,
Pavel
Reply #2 - Apr 22nd, 2008, 4:42am
Thank you for response, Didac.
For my simulation I need equivalent schema for only one frequency. So in my AC simulation setup there was one frequency and Vin was a parameter.
If I properly understood you, I can use C(Vin), R(Vin), extracted from AC analysis, for my transistion analysis?
And these values (I mean AC-measured C(Vin), R(Vin)) will properly represent my "blackbox"?
Thanks.
Pavel.
