Jul 18th, 2024, 5:33am
Setup simulation for SCL MOS divider (Read 1770 times)
vkale
Apr 22nd, 2008, 7:09am
I have a SCL(or CML) divider with fclk=1.5GHz and i would like to simulate in order to get the half of the clock freq. I have set the current to a value that allows to operate the transistors at the expected frequency. But I can't get the right waveform. Is there anything about Spectre(some initial condition thai I must set), or is something else?
Bill
ACWWong
Oxford, UK
Re: Setup simulation for SCL MOS divider
Reply #1 - Apr 22nd, 2008, 2:06pm
if your SCL divide-by-2 is designed correctly and you drive the input at fclk then you should get fclk/2 at the output. There is no need for initial conditions in Spectre transient analysis to simulate this. If it doesn't work, then you have a problem with the design or setup which will not be corrected by initial conditions. More details would be needed for a better diagnosis.
