sugar
akki,
As you mentioned, voltage swing is equal to I*R When you connect a transmission line to your driver, R is reduced. Actually in this case, R = RDN // Z0 therefore, you will see that you voltage swing is reduced a lot, usually reduce to half of your expectation.
--River
