Aug 16th, 2024, 10:17am
About the resistor to ground (Read 3559 times)
gaom9
CHINA
Apr 18th, 2008, 7:50am
I want to know how to calculate the resistor to ground when calculate the POLE and ZERO.
I saw some examples about it, but in some node, I can not find the resistor to ground in small signal model.
And when calculate it, should we short the input and output to ground?
Is there any books about it, please?
Thank you.
Best regards!
View Profile gaom9   IP Logged
Stefan
Re: About the resistor to ground
Reply #1 - Apr 18th, 2008, 9:10am
If anyone is able to understand this question, please let me know Smiley
View Profile 16731287   IP Logged
gaom9
CHINA
Reply #2 - Apr 18th, 2008, 6:11pm
Let's wait for hero together.
Wink Tongue
Best regards!
Stefan
Reply #3 - Apr 19th, 2008, 10:24am
Hi Gaom,
I meant that it's (at least for me) impossible to understand your question. If you want to get a good answer, please refine your question a little bit Smiley
Stefan
gaom9
CHINA
Reply #4 - Apr 19th, 2008, 7:07pm
I am sorry, Stefan
My question is as shown below.
For example, when I calculate the POLE and ZERO of the common-gate amp as shown below. What is the resistor of note X to ground? in its small signal as shown below, Rs and 1/gm//1/gmb is in series, but both of them do not connect to ground, but in Razavi is book, the resistor of it to ground is RS//[1/(gm+gmb)], why? and also the question to note Y.
And should we short the output and input to ground when calculate?
common gate amp
small signal model
Thank you.
Best regards.
Reply #5 - Apr 25th, 2008, 5:39am
Recall that any voltage source is an "ac ground" for small-signal analysis.  Does this help?
