Jul 16th, 2024, 10:34am
external supply pins (Read 2868 times)
ScottO
Midwest
Apr 19th, 2008, 8:06am
Hello. I'm new to VerilogA/behavioral modeling.
Wondering how system level external power supplies and ground pins are typically handled in an analog model.
For instance, say I don't reference a given supply in the model's code, but I want my symbol to have a pin for the supply so it matches the transistor level symbol. Is there a best way to handle such a pin in the model.
Currently I'm trying to model a regulator. I've included external supply and  ground pins. The simulator indicates a voltage loop because, I assume, my model is making an implied short. What are the typical ways of handling this sort of thing, and accessing external supplies in your code?
Thank you,
Scott
Stefan
Re: external supply pins
Reply #1 - Apr 19th, 2008, 10:28am
Hi Scott,
I don't get your point.
If you simply specify two input/output pin in your sourcecode to act as power supplie input(!), then you shouldn't get any messages like voltage loops.
Your sourcecode of the model should look like this:
module NAME(vddpin,gndpin)
inout vddpin,gndpin;
electrical vddpin,gndpin;
analog begin
if V(vddpin,gndpin) > necessarysupplyvoltage
begin
 // functionality here
// this is for virtual power consumption
I(vddpin,gndpin) <+ V(vddpin,gndpin)/ R_something;
Stefan
View Profile 16731287   IP Logged
ScottO
Midwest
Reply #2 - Apr 24th, 2008, 6:05am
Stefan,
Thanks for the reply.
It turned out something in one of my files was corrupted which caused the strange errors. My code was similar to your example, yet didn't work. Being new to this, I thought I my code was incorrect.
Deleting my files, and typing a new model (same code) from scratch fixed things.  :P
Scott
