Jul 16th, 2024, 10:22am
comparator modelling - error during simulation (Read 5694 times)
Pavel
Lausanne/Switzerland
Apr 22nd, 2008, 4:59am
Here is AMS-model of comparator:
module COMPAR_v0 (INP, INN, OUT);
input INP, INN;
output OUT;
reg OUT;
electrical INP, INN;
initial begin
	if (V(INP)>V(INN)) OUT = 1;
	else OUT = 0;
always @(cross(V(INP)-V(INN),+1)) OUT = 1;
always @(cross(V(INP)-V(INN),-1)) OUT = 0;
At the picture below there are waveforms.
Comparator output is connected to comp signal.
INP is connected to envlp, INN - to dac_out.
As you can see at the picture, after 2nd transition ('0'->'1'), output is frozen at '1'.
How to avoid this problem.
Thanks.
Pavel.
Stefan
Re: comparator modelling - error during simulation
Reply #1 - Apr 22nd, 2008, 6:42am
Maybe this is a timing issue of the solver.
Try to set max timestep or use an appropriate $bound_step in your model.
View Profile 16731287   IP Logged
Pavel
Reply #2 - Apr 22nd, 2008, 7:27am
Thank you for response, Stefan
I can't use $bound_step as I have no analog costruction in this configuration.
Finally I resolved the problem. Here is code that works:
real OUTa;
initial begin
	if (OUTa > 0) OUT = 1;
	else OUT = 0;
always @(cross(OUTa,+1)) OUT = 1;
always @(cross(OUTa,-1)) OUT = 0;
analog begin
	@(initial_step) begin
		if (V(INP)>V(INN)) OUTa = 1;
		else OUTa = -1;
	@(cross(V(INP)-V(INN),0))
	if (V(INP)>V(INN))
		OUTa = 1;
	else OUTa = -1;
Regards.
Pavel.
Stefan
Reply #3 - Apr 22nd, 2008, 7:37am
Hi Pavel,
your code generally does the same as the $bound_step function would do.
It makes the analog solver produce an calculation closer to the crossing, so that it can be detected from the digital part.
If you use wavescan to plot your first grafic you might see that there is no analog waveform crossing at the second falling edge.
Can you confirm that ?
There should be a better way to make a working code than your (well working, but pretty difficult to read) code.
Stefan
Reply #4 - Apr 22nd, 2008, 2:35pm
Try tightening the tolerances on the cross functions.
jbdavid
Reply #5 - Aug 27th, 2008, 1:10am
or try writing it as a single cross statement with tolerances
initial OUT = V(INP,INN) > 0;
always @(cross(V(INP,INN),0,vtol,ttol)) OUT = V(INP,INN) > 0;
But you do need a decent circuit feeding you INP and INN
or you won't get enough timesteps on the analog side anyway..
above is an interesting function to look at too.
jbdavid
jbdavid
Reply #6 - Aug 27th, 2008, 1:19am
your working model is effectively
initial OUT = V(INP,INN) >0;
always @(cross(OUTa)) OUT = OUTa >0;
analog OUTa <+ (V(INP,INN) >0)? 1:-1;
so the cross statement in the analog block only forces a timestep at the crossing, but equation (not inside the cross) ALSO forces a timestep there because of its discontinuous nature (which is probably going to cause a problem in a larger simulation. )
jbdavid
