Aug 15th, 2024, 8:54am
VCO jitter (Read 3084 times)
lianggu
VCO jitter
Apr 23rd, 2008, 12:36pm
When I use (74) and (78) in "predicting the phase noise and jitter of PLL based frequency synthesizers" to calculate VCO jitter, however, the result is very different from what I get when I use (14) in JSSC 2006, p. 1806.
I am very confused. Which one is right?
« Last Edit: Apr 23rd, 2008, 4:56pm by Forum Administrator »
Re: VCO jitter
Reply #1 - Apr 24th, 2008, 12:10am
lianggu wrote on Apr 23rd, 2008, 12:36pm:
Who can understand your question ?
"predicting the phase noise and jitter of PLL based frequency synthesizers" is paper's title in JSSC 2006, p.1806 ?
If so, you should show author's name and number of JSSC or published month.
What are (74), (78) and (14) ?
Are they equation's number ?
Do you refer to the following paper and equations in it ?
I can't find (74) and (78) in it.
TITLE: Phase noise and jitter in CMOS ring oscillators
ISSUE: IEEE Journal of Solid-State Circuits, vol. 41, pp. 1803 - 1816, August 2006
AUTHORS: Asad A. Abidi
BIBLIOGRAPHIC ENTRY:
A. A. Abidi, "Phase noise and jitter in CMOS ring oscillators," IEEE Journal of Solid-State Circuits, vol. 41, pp. 1803 - 1816, August 2006.
lianggu
Re: VCO jitter
Reply #2 - Apr 25th, 2008, 9:44am
"predicting the phase noise and jitter of PLL based frequency synthesizers" is NOT a JSSC paper. it is posted on this website. Ken Kundert is the author. Its version is 4g, August 2006. Equations (74) and (78) in this pater give a method how to calculate VCO jitter based on phase noise.
Abidi's "Phase noise and jitter in CMOS ring oscillators", JSSC 2006, p1803-p1816 gives another equation (14) to calculate VCO jitter based on phase noise.
But I can not get the same results when I use Ken's and Abidi's methods.
